Is it a bad idea to use bottom layer for Power?
Susano , 04-07-2026, 08:28 PM
I know the gold standard is Signal-Gnd-Gnd-Signal for 4 layer board but I'm wondering why everyone is debating about stackups like 1- Sig-Gnd-Pwr-Sig2- Sig-Gnd-Sig-Pwr3- Sig-Gnd-Gnd-SigI know we have to be careful with replacing the inner planes with pwr because of the signal to gnd plane thickness is different between L1 and 2 and L1 and 3 and the splits in the power planebut I was wondering why not just pour my bottom layer with Power too ? I mean what are the cons of sharing the bottom layer between signal and pwr in other words (Sig/Gnd pour-Gnd-Gnd-Signal/Pwr pour) keeping in mind a 3x Dielectric thickness of clearance or more of course to reserve the non coplanar impedance
Robert Feranec , 04-08-2026, 06:06 AM
if i have two GND inside I use sig + pwr outside
Susano , 04-08-2026, 12:29 PM
I'm routing pwr on L1 and L4 anyway but the idea was instead of pouring the exceess space on top and bottom to Gnd like usual what about pouring L4 with PWR instead this would make the top layer much cleaner for signal routing I don't see it used often though most people route power and just pour gnd for the excess space on top and bottom layer so I'm wondering why what are the tradeoffs
QDrives , 04-08-2026, 03:50 PM
First question is what speeds are we talking (rising edge times)?The problem with power as a plane is getting the return energy back to the source.If the power plane is 3.3V and your sources uses that 3.3V power to drive the signal, then there is not problem.However, if your source uses another power source, then you need the return energy to somehow return to the source. That is through capacitors.When pouring the bottom layer, you should also pour to the top layer to balance the copper. If you don't, your baord may bend.Same goes for inner layers (e.g. Sig - Gnd - Sig - Gnd).
Susano , 04-08-2026, 08:21 PM
I'm talking about signals of 5 ns and lessI know your point about referencing plane however L1 and L4 signals would be referencing L2 and L3 gnd planes so it shouldn't be a problem to pour L4 with 3.3V and route some signals on the same layer right ? assuming I keep enough coplanar clearance of course ? if so why don't I see this often
QDrives , 04-09-2026, 12:13 AM
"*if so why don't I see this often*" -- Because most designers just copy. Copy from other designers, other designs or people like Eric Bogatin.And no, it is not a problem to pour 3.3V on L4... except: you need to balance copper, so you may also need to pour on L1.
Robert Feranec , 04-09-2026, 05:46 AM
This video can also help: https://youtu.be/kdCJxdR7L_I
