About decoupling capacitors on the other side
mulfycrowh , 05-10-2022, 04:16 PM
Hi everyone,
Usually decoupling capacitors are on the same board side than the component for which they are used.
Sometimes for space issues, we want to place them on the other side of the board.
Since the capacitor and the component are not on the same side of the board, we obviously need one via between both layers.
We have 2 options as shown on the attached screenshots.
I think that both configurations are not good.
They are not because, if we assume having a power plane in internal layer, the current flows directly from the via to the component.
It acts as if the capacitor were not present.
When we have the capacitor on the same side than the component, the capacitor is located between the via and the component.
In that case, the component is supplied with a current that first flows into the capacitor.
Would it mean that placing decoupling capacitors on the other side is always worse than having them on the same side ?
Thanks for ideas !
qdrives , 05-11-2022, 02:29 PM
What is the stack-up?
Often, power, gnd or both come from another layer. Also, 3V3 is on one end and gnd on the other end of the component.
Both traces and via's have inductance (as do planes, but they are a lot smaller due to their width.)
Alternatively, if the power plane is close to the gnd plane, you do not need the decoupling capacitors close to the component. (<=0.2mm or 8mil)
But why not place the capacitor directly underneath the component like the attached picture?
mulfycrowh , 05-11-2022, 02:57 PM
The stack-up is:
Signal
GND Plane
Signal
Power Plane
Power Plane
Signal
GND Plane
Signal
In your picture, the link to the power supply directly comes the power plane and not from the capacitor.
I think there is no other solution.
robertferanec , 05-13-2022, 08:06 AM
Once the cap is on the other side, from the point you are asking about, I don't think it is really important where exactly the via is. We just would like to keep both tracks as short as possible. At least that is how I would do it.
However, when connecting positive and negative pads of decoupling caps, often we may want to have these two vias placed close to each other.
qdrives , 05-13-2022, 02:58 PM
"...power supply directly comes the power plane and not from the capacitor" - it all depends on the impedance.
Do you need two power planes in the middle?
Decoupling...
![](https://i.ytimg.com/vi/5Ca0Eah7eKI/maxresdefault.jpg)
Change the way how you look at powers on your board.Part 2: PCB Layout & Decoupling - Understanding Impedancehttps://youtu.be/Tt8X6_maj6cPart 3: PCB Layout &...
![](https://i.ytimg.com/vi/XumNc480qYo/maxresdefault.jpg)
How much better is it to connect decoupling capacitor with a wide track comparing to a narrow track? Is it really a huge difference? What do you think?Links:...
And even the latest is good:
https://www.youtube.com/watch?v=WdlN8bHw-w0Use our interactive
