i have follow the advanced hardware design and now i have redesign this pcb attached where we have had many problem related to:
⦁ Emi emissions in the points of the images
⦁ We have heating problem connected to the power absorbed by our device, 24W more or less distributed on the 5,7,12V.
⦁ Clock signal problem on the line MCLK to the codec audio U1
so in this relayout i have:
⦁ redesign the RMII ethernet net, metched the length, set a width as described in this
guide pag.17, redesign the differential ETH nets TX and RX, remove the GND plane under the magnetic chip
⦁ Used the layer in different way. The TOP and BOTTOM layer are for high speed nets, layer 2 and 5 as GND, layer 3 and 4 for power supply and signals. In layer 5 a small part is used to renforce the 12,7,5V connection to the connector J3.
⦁ The SAI (or I2C) signal are designed using the width same as for the ETH RMII to reach the 50ohm impedence. A low length matching is done on these signal because i have more or less 5cm of signal length to the microprocessor that is on a different board. The MCLK work at 12Mhz
this is my first work with fast net, what are you impression about this layout? Do you have suggestion how to improve this?
Thanks all
