Routing technique for 2 chips of DDR3
Luca82 , 04-17-2019, 02:29 AM
Usually the address/command/control/CLK of any DDR3 is routed in a fly-by topology (+ some write levelling to adjust skews).
When we have only two chips of DDR3 (4Gb each) to route (both on top as the microprocessor), I'm wondering if a T-branch topology would have an interest, since only two chips need to be routed (even if more effort than the fly-by topology).
Any ideas ?
Thanks a lot,
Luca.
mairomaster , 04-18-2019, 01:40 AM
I always use t-branch when routing 2 chips of DDR3. Probably most of the people do like that as well. Fly-by becomes more valueable for 4 chips.
EDIT: 500th post day
Luca82 , 04-18-2019, 01:58 AM
Thanks a lot MairoMaster ! Do you see any major disadvantage in routing the two chips of DDR3 in a fly-by topology ?
Thanks a lot !
robertferanec , 04-18-2019, 08:10 AM
DDR3 can be definitely routed as T-branch if chip manufacturer recommends this (if not recommended or mentioned in the chip documentation, then be extra careful). T-Branch on DDR3 will work fine up to certain frequency - I know it works ok for 533MHz. I am not sure how much higher you can go ... also it depends on termination resistors (for higher frequencies, termination resistors are important).
- You need termination resistors and voltage => more space, possibly also higher power consumption
- @mairomaster Thank you so much
