Why Wont the pad and pin connect?
The Chosen One , 06-16-2024, 01:57 PM
So I have a ground plane poured on top of the PCB, but for some reason the pad and pin of the ESP-32 wont connect to it. Any idea why? Attached the schematic, PCB, and polygon pour for reference
The Chosen One , 06-16-2024, 02:38 PM
Still didnt connect the ground pad to the ground
The Chosen One , 06-16-2024, 02:41 PM
Arkev , 06-16-2024, 02:48 PM
Just started looking at it and wondering the same thing, I just don't understand what's going onCould need a repour, or maybe you need a via to make the GND connection ? I don't understand what's supposed to be connected where/how
The Chosen One , 06-16-2024, 03:06 PM
What is standard colour scheme?
The Chosen One , 06-16-2024, 03:08 PM
Hope this makes things a bit more clear
The Chosen One , 06-16-2024, 03:09 PM
The pad in the middle of the MCU is supposed to be connected to GND. But for some reason, it has an airwire to the GND pin of the MCU and I dont know why
The Chosen One , 06-16-2024, 03:10 PM
Just a warning about the pin type
The Chosen One , 06-16-2024, 03:11 PM
The Chosen One , 06-16-2024, 03:12 PM
Should I just change it to a Power Pin?
its currently an I/O pin
QDrives , 06-16-2024, 04:08 PM
What is the thermal relief setting of that pad?
The Chosen One , 06-16-2024, 04:47 PM
its uncheckewd
The Chosen One , 06-16-2024, 04:48 PM
Mini , 06-16-2024, 07:27 PM
Probably something with the symbol. hard to help you like that. Try different symbol/footprint and see if it works. Also try putting via down. I would put via-s down anyway assuming you have GND plane below.
The Chosen One , 06-16-2024, 07:38 PM
Heres the libraries with the schematics, the part is ESP-blfsf
Arkev , 06-16-2024, 08:28 PM
You've got two pads in one
so one's blocking the other
i'd guess
The Chosen One , 06-16-2024, 08:47 PM
could it also be the reason its not mounting to the gnd plane
Arkev , 06-16-2024, 09:06 PM
Yes, try deleting the pad and then update the component
The Chosen One , 06-16-2024, 09:27 PM
Now it keeps saying unknown pin
The Chosen One , 06-16-2024, 09:28 PM
Arkev , 06-16-2024, 09:45 PM
Have you deleted the P$1 or the 41_GND ?
Arkev , 06-16-2024, 09:47 PM
You do need one of the two, probably the P$1The issue is with them overlapping - one's trying to connect to GND while the other, likely with no net, blocks it
The Chosen One , 06-16-2024, 10:38 PM
I tried deleting both
Both had the same error
The Chosen One , 06-16-2024, 11:06 PM
Also, why are these red X's showing up
That might be part of the reason why I cant get it to route to GND
Arkev , 06-17-2024, 03:36 PM
It's a conflict but you should have a message explaining it
QDrives , 06-17-2024, 03:53 PM
Those cross symbols are DRC error notifications. You changed the colors here too, it should be green. The yellow circles indicate a clearance problem.As for the problem that a pin cannot be found - that is the mismatch between the schematic symbol (on the schematic) and the footprint (on the board or library).
