QDrives , 11-09-2024, 10:22 PM
"...but then I have to adjust the connectors..." -- What do you mean with adjust? Do you mean position?If you mean position:- Create footprint for the connectors- Create a footprint for the SOM, where you have some points that you can snap to. This allows you to add the 3D model of it too. This component could be set to "standard no bom".- Position the SOM on the board.- Position the connectors using the 'snap points'Actually, You may even be able to add snappoints in the footprint. I have never tried it though.
