SIMCOMM hat module.
Let's_see_Ashley , 09-23-2024, 09:42 AM
Hello everyone!
I'm working on a small project to DIY the SIMCOMM Raspberry Pi hat. I've played along with dimensions, and have elongated.
Can anyone please review the schematics and the PCB layout?
QDrives , 09-23-2024, 12:17 PM
We cannot review a schematic if none is provided.
Which layer is the one with orange traces? You may want to pour copper there to to balance the copper.
Let's_see_Ashley , 09-23-2024, 12:47 PM
sorry My mistake. I forget to attach the schematic. PFA in this messege.
Let's_see_Ashley , 09-23-2024, 12:48 PM
it is In.Cu-2. In-Cu-1 is the green one with a solid ground plane.
QDrives , 09-24-2024, 11:56 AM
"In.Cu2" -- I assume a KiCad name?
Anyhow, you have 3 layers full of copper and one barely. This will make your board bend. Keep copper balanced between the layers (symmetry).
Let's_see_Ashley , 09-24-2024, 02:52 PM
Okay thanks for this feedback will do it.
Let's_see_Ashley , 09-24-2024, 02:53 PM
I want to know if there is any specific guidelines for routing CLK trace. Like any standard impedance control.
QDrives , 09-24-2024, 03:06 PM
Why have a capacitor on them?
And why is the clock resistor 0 ohm and data 22 ohm?
Let's_see_Ashley , 09-25-2024, 10:15 AM
hi, I've used the interface circuit shown on the datasheet of the module. It's shown to have 22ohm resistor for clk signal with 22pf capacitor pulled down.
Let's_see_Ashley , 09-25-2024, 10:18 AM
> The rise/fall time of USIM_CLK should not be more than 40ns.
this is stated for the CLK signal. How can I use this information to calculate the impedance for the trace? and what should be taken care.
QDrives , 09-26-2024, 07:25 PM
That depends more on the output driver. I assume the Raspberry Pi.
If the rise/fall time must be fast, than it is better not to add a capacitor. You also have a TVS diode for protection, so you do not need a capacitor.
