Schematic differential pair
 , 07-03-2025, 01:41 PM
Hi im sharing a schematic that was designed in Altium can anyone share how can we implement this differential pair in our design in Altium.
QDrives , 07-03-2025, 01:58 PM
What do you need to know?- That you need to name your differential pair differently? --> \*_P  and \*_N- How to place differential pair directive? --> Place / Directives / Differential Pairs- How to place the parameter set? --> Place / Directives / Parameter Set- Or something else?https://www.altium.com/documentation/altium-designer/defining-differential-pairs-schematics
 , 07-05-2025, 06:37 AM
Hi Thankyou for sharing  documenting i will be reading out.Yes, I want to know about placing  parameters set and also pairing the directive also what is the use of differential pair i mean significance.
QDrives , 07-05-2025, 03:14 PM
You use the parameters set to assign the characteristic impedance for the differential pair. This is only really useful if you need different impedances for different pairs.https://duckduckgo.com/?q=why+use+differential+pair+over+single+ended+signals&atb=v314-1&ia=web
