Routing Issue on connecting Microcontroller pads in KiCAD
Techcurious , 08-07-2025, 06:06 PM
Hi @Robert Feranec / @Phil ,I am currently taking Mixed signal hardware desing course. During the layout, I can't able to connect the track from capacitor pads to microntroller pads, there is no connection (see gnd track) or misalignment (see +3V3 track). Also, I can't able to route the tracks starting from microcontroller first, see the violation in green color. Please let me know how I can resolve this issue?
Techcurious , 08-08-2025, 02:10 AM
Can someone who has experience with Kicad provide response please for the above question?
Robert Feranec , 08-08-2025, 05:48 AM
is this not something with minimum clearance?
Techcurious , 08-08-2025, 01:04 PM
@Robert Feranec  It seems like not, I reduced the minimum clearance to even 0.15mm, still showing the issue.
Techcurious , 08-09-2025, 03:26 PM
@Phil, can you please provide response to this question, I am stuck at this point, still didn't know why this issue is happening.
Techcurious , 08-09-2025, 04:35 PM
Please see the below image, I have 0.2mm pitch between the pads, just want to make sure if I am using correct symbol.
Phil , 08-11-2025, 08:39 AM
@Techcurious How are your design rules set-up (i.e. pad-to-pad clearance, trace-to-pad clearance, etc.)? You may have to reduce these rules to route in/out of the pads. Alternatively (or in addition), you can start routing with narrow traces in/out of the pads, and then widen as the design rules allow.
Techcurious , 08-11-2025, 12:36 PM
After reducing the trace width to 0.2 mm, it resolved the issue. Seems like our footprint models might be different.
