Review Request] Smart Shutter Control System - Schematic Design
phanvanduy , 05-09-2026, 12:43 PM
Hi Teacher Robert and everyone,
I am working on a Smart Shutter Control project. I have just finished the schematic and would really appreciate it if you could take a moment to review it.
Could you please provide some feedback or suggestions for improvement before I move on to the PCB layout? I want to make sure the design is solid.
Thank you so much for your support!
phanvanduy , 05-09-2026, 12:47 PM
"Dear Teacher Robert,
I would like to express my deepest gratitude for your guidance and for taking the time to respond to my post. As a student in your community, receiving direct advice from you is a tremendous honor and a huge motivation for me.
I have successfully moved my Smart Shutter project to the Q&A section as you suggested and am looking forward to learning from the feedback. Thank you for being such a great inspiration and for helping me grow in my electronics journey.
Best regards,
Duy”
, 05-09-2026, 12:53 PM
Here are key schematic review considerations based on the video content, presented as an experienced engineer would advise:
1. **Reference Design Validation**
Always verify against manufacturer evaluation boards. One video shows how missing eval board documentation can indicate potential risks ([Video 1](https://www.youtube.com/watch?v=Rfsq0EwJ5Xs&t=6)). For any ICs in your design:
- Confirm power sequencing requirements
- Check for undocumented application circuit components
- Include all recommended decoupling capacitors
2. **Reset Circuit Design**
The Arduino review video demonstrates critical reset circuit best practices:
- Use RC network for proper power-on reset timing
- Include debouncing capacitor (10-100nF typical)
- Add protection diode if using external reset button
([Video 11](https://www.youtube.com/watch?v=2GlWCwyEKuM&t=6))
3. **Power System Checks**
From multiple layout examples:
- One 100nF capacitor _per_ power pin + bulk 10µF capacitor
- Separate analog/digital power domains with ferrite beads
- Mark test points for critical power rails
([Video 10](https://www.youtube.com/watch?v=YzBtfN1LQtM&t=183))
4. **Connector Best Practices**
As shown in keyboard and Arduino designs:
- Clearly mark Pin 1 on all connectors
- Include mating component keepout zones in notes
- Add reverse polarity protection for motor connections
([Video 15](https://www.youtube.com/watch?v=2GlWCwyEKuM&t=1621))
5.
**Signal Integrity Fundamentals**
From high-speed design reviews:
- Add series termination resistors (22-47Ω) on clock lines
- Separate analog/motor control grounds
- Use net labels instead of direct wiring for bus signals
([Video 8](https://www.youtube.com/watch?v=2GlWCwyEKuM&t=1044))
6. **Design for Manufacturing**
As demonstrated in PCB tutorials:
- Include test points for programming interface
- Add assembly notes for any flipped components
- Verify all component packages match distributor stock
([Video 6](https://www.youtube.com/watch?v=bcvq30J4SnQ&t=1801))
For optimal review, share:
1) PDF schematic with visible net names
2) Bill of Materials with manufacturer part numbers
3) Key component datasheets (especially motor driver & MCU)
Would you like me to elaborate on any specific aspect of these recommendations?
phanvanduy , 05-09-2026, 01:00 PM
"Dear Teacher, thank you for the helpful suggestions, especially regarding the decoupling capacitors and ferrite beads. I will review the videos you recommended before finalizing my schematic. I really appreciate your support for my project!”
QDrives , 05-09-2026, 07:17 PM
1) Have your schematic on a 100 mil grid.
2) Draw a transistor as a transistor, not a block.
3) Your LEDs are not going to work as connected.
4) Do not place multiple Gnd symbols on the same (connected) net.
5) Add netnames so it becomes clear what a net does.
6) Why is U4 in series with C5?
phanvanduy , 05-10-2026, 01:43 AM
"Dear Mr. QDrives,
Thank you so much for your valuable feedback on my previous schematic. I have revised the entire design based on your suggestions:
Aligned the schematic to a 100 mil grid for better clarity.
Replaced the block components with proper transistor symbols.
Fixed the LED connections; they are now connected to GPIO pins with appropriate resistors for control.
Cleaned up the Ground (GND) symbols and added clear Net Names (3.3V, LED1-3, etc.) to all connections.
Corrected the AMS1117-3.3 power circuit (the capacitors are now in parallel for proper decoupling).
Additionally, I have added a new feature: 3 Touch Button modules (TTP223) connected to GPIO pins to control the door (Up/Stop/Down).
I have attached the EasyEDA source file for your review. I look forward to hearing your thoughts. Thank you for your guidance!
Best regards,
Duy”
phanvanduy , 05-10-2026, 01:44 AM
phanvanduy , 05-10-2026, 04:01 AM
"Dear Mr. QDrives,
I just wanted to send a quick note to express my sincere gratitude for your guidance. Your detailed feedback on my schematic means a lot to me, and it has helped me learn so much more about professional design.
Thank you for being so patient and supportive of my learning journey. I truly appreciate the time and effort you spend helping students like me!
Warm regards,
Duy”
QDrives , 05-10-2026, 01:24 PM
Have you got the new schematic in PDF or screenshot too (no photo)?
phanvanduy , 05-10-2026, 01:24 PM
phanvanduy , 05-10-2026, 01:29 PM
"Hi there, I have attached the PDF and screenshots of the new schematic. Please let me know if you need anything else. Thank you!”
phanvanduy , 05-10-2026, 01:35 PM
"Dear Teacher, I would like to express my deepest gratitude for your constant care and support. Your kindness and the encouragement you have shown me mean a lot to my journey. I truly appreciate everything you have done for me. Thank you so much!”
QDrives , 05-10-2026, 07:35 PM
1) What about the transistor symbols?
2) Draw U3 with power in left and (both) outputs right. Gnd either left or right.
3) Have net labels at the MCU pins (green arrows). Best not to have pins on the top or bottom as adding net labels are more difficult to read.
4) You LEDs still not going to work
4) EN reset is shorted to Gnd.
5) Add pull-down resistors on the transistor bases.
100 mil grid is **not** for clarity, but for possible 'misconnection'. Having a wire close to a pin, but not connected. Zoomed out, you miss it.
Also note that most people here, me included, cannot read Vietnamese. But it does make things a bit more private for you.
phanvanduy , 05-10-2026, 10:11 PM
phanvanduy , 05-10-2026, 10:59 PM
"Dear Teacher QDrives,
Thank you so much for your detailed feedback on my schematic. I truly appreciate the time you spent pointing out my mistakes, especially the critical error on the EN pin and the layout of U3.
I have noted all your suggestions regarding net labels, pull-down resistors, and the grid settings. I am heading to work now and will carefully revise the entire circuit tonight once I'm back.
I look forward to sending you the updated version for further review. Thank you again for your guidance!”
Robert Feranec , 05-11-2026, 01:34 PM
I would recommend you to have a look at my ESP32 schematics or my Keyboard schematics. Try to draw it similar way. The reason why your schematic has some basic mistakes is because it is not easy to read. There are some unwritten conventions that are often used and if you follow them you will immediately spot the mistakes e.g. your LED mistakes: https://oshwlab.com/robertferanec/works
phanvanduy , 05-11-2026, 01:35 PM
phanvanduy , 05-11-2026, 02:18 PM
I would like to express my deepest gratitude for the opportunity you have given me to learn from your courses. I feel very honored and grateful that you allowed me to study your professional designs. It is a huge motivation for me to work harder and improve my PCB design skills.
Thank you for being such an inspiring mentor. I wish you all the best!
Best regards,
Hoc Trò Duy.”
phanvanduy , 05-12-2026, 02:21 PM
I am still trying my best every single hour. Thank you so much for giving me the opportunity to learn this knowledge that I never even dreamed I could have.
Best regards,
Hoc Tro Duy.”
phanvanduy , 05-14-2026, 02:34 PM
Subject: Updated Schematic for Review - Smart Shutter Project
Thank you very much for your detailed feedback on my "Smart Shutter" project. I have carefully revised the schematic based on your suggestions:
100 mil Grid: I have set the grid to 100 mil and re-checked all connections to avoid any "misconnections" or "invisible" gaps between wires and pins.
EN Pin Fix: I have corrected the error where the EN (Reset) pin was shorted to Ground.
Transistor & Pull-down: I added pull-down resistors to the transistor bases as you recommended to ensure stability.
Component Layout (U3): I have redrawn the U3 block with power input on the left and outputs on the right for better clarity.
Net Labels: I added net labels to the MCU pins and ensured they are not placed on the top or bottom to keep the schematic easy to read.
LED Circuit: I have reviewed and adjusted the LED section so it can function properly.
English Labels: I have updated all the block titles and notes to English so everyone can understand the design.
Could you please take a look at my updated version when you have time? I really appreciate your guidance and support for my learning.
Best regards,
HOC TRO DUY
phanvanduy , 05-14-2026, 02:38 PM
Subject: Thank you for your guidance & seeking your advice on my project
Dear Mr. Robert Feranec,
I am writing to express my sincere gratitude for all the tutorials and shared schematic designs you have provided. They have been an invaluable resource for me, and I have been using your designs as a foundational reference for my "Smart Shutter" project.
To be honest, I am currently at the early stages of my learning journey. While I have used your schematics to understand how to build my circuits correctly, I realize I still have a lot to learn and haven't fully developed my own original designs yet.
As I continue to work on improving my skills, I would be deeply grateful if you could share any advice on what I should focus on next to become a better designer. If you have a moment, I would also appreciate any critique or suggestions on the approach I am taking with this project.
Thank you once again for your inspiration and for sharing your knowledge with the community.
Best regards,
Hoc Tro DUY,
QDrives , 05-15-2026, 10:38 AM
1) LED5 LED6 still wrong orientation
2) Gnd connection of U3 missing
3) "IO38" and "IO39" netnames do not describe what it does. Use netnames that make clear what the function is.
Robert Feranec , 05-15-2026, 11:13 AM
also, I would maybe not recommend to use 220V for this initial design - it may be too dangerous. You can use USB-C to power up your board, much safer.
phanvanduy , 05-15-2026, 01:04 PM
"Dear Robert, thank you so much for taking the time to review my design. I am truly honored and grateful for your valuable feedback, especially the safety advice regarding the use of USB-C. It means a lot to me and gives me so much motivation to keep learning. Best regards!” Hoc Tro Duy
phanvanduy , 05-15-2026, 01:08 PM
"Hi QDrives, thank you so much for your detailed feedback on my design. I've noted down the issues with LED orientation, the missing Gnd for U3, and I will definitely rename the netnames to be more descriptive. I really appreciate your help!”
Hoc Tro Duy
phanvanduy , 05-15-2026, 01:09 PM
phanvanduy , 05-15-2026, 02:53 PM
"Dear Robert, I have updated my design to use USB-C for safety as you suggested. I have also been studying and applying your schematic structures to my project. May I have your permission to use your schematic concepts as a reference for my learning journey? Your guidance is a huge inspiration to me. Thank you so much!”
"Hi QDrives, thank you again for your detailed feedback! I have fixed the LED orientations, connected the missing GND for U3, and renamed the nets for better clarity. I am using your advice to improve my design for learning purposes. I hope it's okay for me to follow your guidance as I practice. I truly appreciate your help!”
phanvanduy , 05-17-2026, 09:55 AM
I am writing this message to express my deepest gratitude to you. Thank you so much for your inspiring courses and great guidance at FEDEVEL. Your dedication and knowledge have truly helped me find a brand new path and a huge motivation in electronics engineering. Inspired by your teachings, I am currently designing a new project: a cute smart speaker with LED lights and expressive blinking eyes! Thanks to you, I am working hard on my own projects with confidence every day.
Wishing you all the best, good health, and great success with your upcoming projects!
Sincerely,
Hoc Tro Duy
QDrives , 05-18-2026, 10:44 AM
No, you did not correct the LED orientation. You may have made it worse as now all are incorrect.
https://pcbasic.com/blog/led_polarity.html
phanvanduy , 05-18-2026, 11:26 AM
Hi QDrives,
Thank you so much for your patience and for pointing out my mistake again. I truly appreciate your guidance!
I have carefully read the article you shared about LED polarity and finally realized where I went wrong. I have updated the schematic and corrected the orientation for both the Power LED and the User LED (Anode connected to +3.3V and Cathode to GND/IO42).
I would be very grateful if you could take another look at my updated design when you have time. Thank you once again for being such a wonderful mentor!
Sincerely,
Hoc Tro Duy
Robert Feranec , 05-18-2026, 12:04 PM
phanvanduy , 05-18-2026, 12:16 PM
Thank you so much for taking the time to review my schematic! Your feedback on the relay driver circuit is incredibly valuable to me.
I realized that I made a mistake with the placement of the current-limiting resistors (R15/R16) and the orientation of the flyback diodes (D1/D2). I will correct them immediately so the relay and transistors can work safely and properly.
Thank you once again for your amazing guidance and for helping me learn!
Best regards,
Hoc Tro Duy
phanvanduy , 05-20-2026, 12:55 PM
Dear Mr. Robert,
I hope you are doing well.
Recently, thanks to your guidance, I have been working on the PCB design for my "Smart Shutter" project. I am currently finalizing the design and planning to manufacture a prototype to test its performance.
Since this project is very important to me, I have a strong desire to develop it into a real-world product. My goal is to eventually bring this solution to others, which would also help me support myself while pursuing my passion for engineering.
I would be very grateful if you could share your advice on how I can further develop this product. Specifically, what should I focus on to ensure the safety and reliability of the device when used in real-world conditions?
Thank you so much for your time and for all the knowledge you have shared with me.
Best regards,
Hoc Tro Duy
Robert Feranec , 05-21-2026, 02:06 PM
you need to get confidence in yourself. you can just build it and fix it and then build again. this board is simple even if something is wrong you will be be able to wire it up. if you don't feel confident, use breadboard to test the sub-circuits. I have done many videos about production, testing, product development ... you can watch them they will help: https://www.youtube.com/@RobertFeranec/search?query=product
phanvanduy , 05-21-2026, 02:18 PM
"Dear Robert,
Thank you so much for your kind words and valuable advice. I truly appreciate you taking the time to review my work. Your encouragement gives me a lot of confidence to keep going.
I will follow your advice, start testing the sub-circuits, and keep building, fixing, and improving. I’m really excited to turn this project into something great. I’ll definitely check out your videos on product development as you suggested.
Thank you once again for your mentorship!
Best regards,
Hoc Tro Duy
phanvanduy , 05-25-2026, 01:47 PM
"Dear Robert, thank you once again for your mentorship. I'm learning a lot from your guidance. One day, I hope to have the honor of taking a photo with you at the SMT factory. It would be a dream come true!"
Học Trò Duy🥰
phanvanduy , 05-25-2026, 01:53 PM
"Dear Robert, thank you again for your continued support. I have a new idea for my project: I would like to integrate a surveillance camera into the system to enhance its smart home capabilities. Could you please share your advice on this? Also, may I have your permission and guidance to pursue this development? One day, I hope to have the honor of taking a photo with you at the SMT factory. Thank you so much for your mentorship!"
Học Trò Duy
