Proper Reset Line Routing: TVS, MCU, SWD, and Push-Button Integration
Joel R. , 04-11-2025, 08:02 PM
Hello, I'm designing a reset circuit for an STM32-based board and want to double-check the correct routing of components involved in the reset line. Here’s my setup (Image 1 schematic):- An SWD debug connector (with RESET pin) - A 49.9Ω resistor between the MCU’s NRST pin and a TVS diode for ESD protection- A push-button (manual reset) with a capacitor and pull-up resistor- All these three subcircuits share a common net, which I call *RST_PIN* (in the images is *~{RST}_PIN*)What I think the routing should be (Image 2 PCB layout):1. MCU:NRST pin (MCU) → 49.9Ω resistor  → TVS cathode → *RST_PIN*2. SWD:*RST_PIN* also connects to SWD RESET pin3. Push-Button Circuit:Button + Capacitor + Pull-up → all tied to *RST_PIN*My question: Should I route *RST_PIN* using a copper fill (Image 3) to tie all these nodes, or should I use traces that branch from a central node (Image 2)?What if I want to maintain 50Ω controlled impedance for the RESET trace (my stackup requires a 6.16 mil trace width for 50Ω).Can anyone confirm this layout is solid or suggest improvements? Thank you.
Joel R. , 04-11-2025, 08:06 PM
Image 3
QDrives , 04-11-2025, 08:36 PM
You want the TVS diode closest to the ESD causing sources (eg connector and button).Small track from the TVS toward the MDC.Capacitor closer to the MCU.
