Micro via &  through-hole via
Haythemjls , 03-28-2025, 01:27 PM
When do we decide to use either micro vias or through-hole via while performing routing on a multilayer PCB? Are there recommendations and guidelines for that?
Robert Feranec , 03-28-2025, 03:44 PM
I use uVIAs only on very high density PCBs (or sometimes they are used if you don't want stubs in very high speed designs or if you use a BGA with very small pitch or/and two many pins) - they will make PCB more expensive. If possible I only try to use through hole VIAs.
Haythemjls , 03-28-2025, 09:34 PM
Is it recommended to use through-hole Vias instead of µVias to connect GND and PWR pads in all designs?
QDrives , 03-29-2025, 04:59 PM
https://www.researchgate.net/figure/RCI-versus-DEN-for-HDI-stacked-microvias_fig1_233542381https://www.protoexpress.com/blog/design-manufacture-staggered-and-stacked-vias/
