LLC FB dilema
Sniper2 , 01-25-2025, 04:45 PM
here is my situation:
Sniper2 , 01-25-2025, 04:46 PM
Regarding the PCB here is what is bothering me atm:
1 LLC controller is situated above the HV DC bus (24V output is on the bottom right) and i am not sure if i should put it on the upper side on the opposite with with the 24V output but then FB signal does not cross the HV DC bus OR but it close to the 24V output but then i cross the HV DC buss.
Not sure what is the best option here.
2 I am also wandering if it would be ok to have the the synchronous rectification UNDER the transformer, well it is on the other PCB side. There will be enough clearance so isolation is not my concern it is that EMC or some sort of noise will mess up the rectification control chips ( never used this type of chip before.
QDrives , 01-26-2025, 12:07 AM
Is that a gap in the board for creepage?
What is the distance between the sides of the transformer?
Feedback not using an opto-coupler?
How many layer PCB?
Sniper2 , 01-26-2025, 11:00 AM
2L atm
FB is with an optocoupler
36mm pin to pin on the transformer
gap on the board atm it is a 3mm placeholder it is a blue lines you see
QDrives , 01-26-2025, 04:55 PM
For point 1 your text seems strange, Like the first 'option' seems good "FB signal does not cross the HV DC bus" yet the words "but then" make it sound bad.
Not having to cross on a 2 layer board is a good thing.
I would not put components under the transformer as the magnetic field go there.
Sniper2 , 01-26-2025, 05:10 PM
situation atm
Sniper2 , 01-26-2025, 05:11 PM
I went with make the FB go a longer route and not cross the high current section
Sniper2 , 01-26-2025, 05:12 PM
but also be on the other side of the board then the output connector
QDrives , 01-26-2025, 07:27 PM
Mains powered?
Capacitor between primary and secondary?
Sniper2 , 01-26-2025, 09:01 PM
yes 230V ac
primari is tied directly to mains
while secondary is galvalicaly isolated
i often see calss Y safety capacitors going across the gap so that they reduice noise
Sniper2 , 01-26-2025, 09:02 PM
i have 1nF calss Y1 it is across the isolation barier under the transformer
QDrives , 01-26-2025, 09:05 PM
Your clearance and creepage is then not good.
That capacitor needs something like 8.5mm creepage. And creepage can also use the component housing.
I think your mains connector also does not have enough clearance between the pins.
Is this a commercial product or purely for hobby?
Sniper2 , 01-27-2025, 05:13 AM
This is for hobby
Sniper2 , 01-27-2025, 05:14 AM
Under the caps I plann to maybe add some milling but pitch is 10mm so maybe I can only use that
Sniper2 , 01-27-2025, 05:15 AM
Regarding mains connector it is inspired by a China psu but if I remember well it is also rated for 500vdc
Sniper2 , 01-27-2025, 05:16 AM
I'll probably add miling between its pins
Sniper2 , 01-27-2025, 05:17 AM
Under the stranformerbi have that 3mm line that I intend to have milled here and there where I am close to high voltages
Even if it is hobby I want to follow same rules as a commercial product
QDrives , 01-27-2025, 03:46 PM
'milling' is only useful if the creepage needs to be big, clearance is already ok and the creepage along the component package is within the requirements.
From what I see, that is not the case.
Look at the picture taken from https://philipmcgaw.com/creepage-and-clearance/
Do note that there is a huge difference between IPC-2221 clearance and international standards like IEC 60335, IEC 60664, IEC 60950, etc.
In short, IPC is easy.
Sniper2 , 01-27-2025, 05:19 PM
thx
ill study a bit
QDrives , 01-27-2025, 09:15 PM
You can find some (older versions of) the standards online.
Sniper2 , 01-28-2025, 05:17 PM
sort of fixed a lot of my problems now
tho it is still work in progress since like for some reason i decided to use 2512 jumpers
Sniper2 , 01-28-2025, 05:18 PM
and then i wander why it is a tight fit*
but yea layout going well but days of work left
THX for the help
Sniper2 , 01-30-2025, 05:18 PM
cuts under a screw terminal is that wild idea or a normal thing?
QDrives , 01-30-2025, 05:36 PM
Both.
As I stated before, the creepage then still goes over the terminal itself, so it does not help (often).
In the mains designs I was involved with, we used 10mm pitch connectors. Or 5mm pitch that skips one to get to 10mm.
Sniper2 , 01-30-2025, 05:53 PM
i was planning to use 5mm and use center as earth
QDrives , 01-30-2025, 06:25 PM
That is what I saw from the ratsnets.
However, it is not something I would do. Line/neutral versus PE should be >= line to neutral.
Being in the middle requires large pitch, side just skip one.
Sniper2 , 01-30-2025, 06:37 PM
this was the plan with L N on top and eath on botoom
Sniper2 , 01-30-2025, 06:38 PM
ill see what alternative connectors i can find and see what fits inside
QDrives , 01-31-2025, 09:03 PM
Pluggable? Like https://www.digikey.nl/en/products/detail/te-connectivity-amp-connectors/282808-3/2222048
Sniper2 , 02-01-2025, 09:47 AM
yes something like that i was considering useing the 5mm pitch version with milling between pins
Sniper2 , 02-01-2025, 09:48 AM
atm i have 24mm lenght in that region available
Sniper2 , 02-01-2025, 09:49 AM
so fiting something large is a bit hard
Sniper2 , 02-01-2025, 09:50 AM
on its side i have like 30 but might be very impractical to bend wires for it
ill need to make a decision soon tho
maybe if i use a different conector bor earth...
Sniper2 , 02-01-2025, 09:51 AM
then i can use the 5mm terminal type and leave center not used + mill slots for it
QDrives , 02-01-2025, 04:36 PM
Or get a connector like this https://www.digikey.nl/en/products/detail/jst-sales-america-inc/B5P-VH/926550
And pull out some (middle) pins (heating them makes it easier)
Sniper2 , 02-01-2025, 06:46 PM
that is also an option i was thinking or curing the mid pin from a screw terminal
Sniper2 , 02-01-2025, 06:47 PM
but useing this stile maybe more practical i still need to decide and see how it fits on the PCB
Sniper2 , 02-04-2025, 09:01 PM
what do u think about something like this ?
https://www.lcsc.com/product-detail/Barrier-Terminal-Blocks_Ningbo-Kangnex-Elec-HB9500-9-5-2P_C60785.html
QDrives , 02-04-2025, 10:29 PM
At a quick glance, it looks promising.
