Tomsauy , 01-15-2025, 02:41 PM
Thanks to all your feedback and comments @Robert Feranec & @QDrives, I was able to improve the design of this very simple board, so thank you for sharing your thoughts πHere are some screenshots of the design incorporating all your input and with both inner layer (Ground & 5V). Feel free to let me know if you think thereβs room for improvement, even though I understand that design has a somewhat βpersonalβ aspect πOn another note, regarding the technical specification of the LEDs, I read the following:βIn practical application circuits, to prevent instantaneous high voltage damage to the internal signal input and output pins of the IC caused by live plugging and unplugging during testing, protective resistors should be connected in series at the signal input and output terminals. In addition, in order to ensure more stable operation between IC chips, the decoupling capacitance between each LED is essential.β andβFor soft or hard light strips with short transmission distance between lamp beads, it is recommended to connect protective resistors in series at the signal input and output terminals, R1, R2, about 500 ohms.βSo I added these two resistors, but I donβt understand the purpose of the resistor at the end of the circuit. If anyone has an explanation, Iβd love to hear it.Thanks again for your help!
