IM73A135 Breakout Board Help
DestinyAwaits , 04-10-2024, 03:41 PM
Package is 0805 for all three Capacitors with Ceramic MCC SMD
DestinyAwaits , 04-10-2024, 03:49 PM
I still need a compatible Differential Amplifier and a 24-bit ADC because I don't think the ESP32 ADC is very good.
Sniper2 , 04-10-2024, 04:09 PM
what dielectric
Sniper2 , 04-10-2024, 04:10 PM
it is not , it is 12bit resolution but in practice 10 if i remember well
DestinyAwaits , 04-10-2024, 04:36 PM
X7R dielectrics
for both
Sniper2 , 04-10-2024, 04:39 PM
not great for audio since it buzzez
DestinyAwaits , 04-10-2024, 04:39 PM
Knowles 0805J0100104KXR for 100nF
Samsung Electro-Mechanics CL21B106KPQNNNF for 10uF
Okay. Which one to choose then ?
CoG dielectric
Sniper2 , 04-10-2024, 04:40 PM
or electrolithic
want a open source reference design ?
DestinyAwaits , 04-10-2024, 04:40 PM
You can provide not sure If I will be able to understand or not
DestinyAwaits , 04-10-2024, 04:41 PM
I will still try to read
Sniper2 , 04-10-2024, 04:42 PM
https://github.com/immortal-sniper1/cross_band_handy_walkie_talkie
there
Sniper2 , 04-10-2024, 04:43 PM
it works
uses esp32 too + some code in there
DestinyAwaits , 04-10-2024, 04:43 PM
is there a way to find these capacitors in https://www.lcsc.com as I do not find them
Sniper2 , 04-10-2024, 04:46 PM
https://www.lcsc.com/products/Aluminum-Electrolytic-Capacitors-SMD_418.html
or
https://www.lcsc.com/products/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT_313.html with COG filter
LCSC/JLC filters are on page not in URL so u need to filter localy
DestinyAwaits , 04-10-2024, 04:50 PM
Package: 0805
Voltage: 10V
Tolerance: +- 10%
Capacitance: 100nF and 10uF
Now Temperature Coefficient disables COG
Please try
Sniper2 , 04-10-2024, 04:53 PM
COG should be stable
try without temp
LCSC filters are bad anyway
DestinyAwaits , 04-10-2024, 04:53 PM
digikey ?
Sniper2 , 04-10-2024, 04:55 PM
https://github.com/yaqwsx/jlcparts
DestinyAwaits , 04-10-2024, 04:58 PM
Updating component library
DestinyAwaits , 04-10-2024, 05:00 PM
I will let you know what I find.Thank you for today. It will take time for me to understand it more. I can say not even close to fabrication step. 🙂
Sniper2 , 04-10-2024, 05:00 PM
i can see
Sniper2 , 04-10-2024, 06:02 PM
so?
do u get it?
QDrives , 04-10-2024, 07:19 PM
You will not find 100nF or 10uF in C0G.
Best is to use electrolytic (polymer) or tantalum. You can add a local C0G for the high frequency (1...10nF).
Sniper2 , 04-10-2024, 07:34 PM
true
DestinyAwaits , 04-11-2024, 01:34 AM
Did not find COG. Now am not sure if package 0805 is correct or not for both 10uF and 100nF?
If possible for both of you can you provide the parts I should use? Finding it difficult to search the right parts. The mems microphone max supply is 3V and I will pair this with 3.3V ESP32 that is why I chose 10V. Can you please share if not links but direct part number to search will be really helpful. 🙏
Sniper2 , 04-11-2024, 04:09 AM
Use lectrolithic
@DestinyAwaits
Sniper2 , 04-11-2024, 04:10 AM
Ps since the audio ends up in a adc / codec you will not care so much about voltage anyway
DestinyAwaits , 04-11-2024, 04:47 AM
@Sniper2 bro can you share the part number searchable on LCSC or any other site? Like I shared earlier as below?
Sniper2 , 04-11-2024, 03:02 PM
It is in my kicad project
@DestinyAwaits
What can't u find?
DestinyAwaits , 04-11-2024, 03:18 PM
I haven't gone through the project yet. Let me check the BOM file to find the capacitors. Thank you @Sniper2
DestinyAwaits , 04-11-2024, 04:29 PM
@Sniper2 the bom in project for one capacitor was using X7R only not COG I checked the part C14663
50V 100nF X7R ±10% 0603 Multilayer Ceramic Capacitors MLCC - SMD/SMT ROHS
Sniper2 , 04-11-2024, 04:37 PM
ok
QDrives , 04-12-2024, 03:45 PM
Pick one from the list
https://www.digikey.nl/en/products/filter/aluminum-polymer-capacitors/69?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIALAAxwDMdIAuoQA4AuUIAymwE4CWAOwDmIAL6EATFQoJoIFJAw4CxMuCoACAK0AxEITCSd%2BwwFYTB8AA5LU43quSA7HZC1ab%2Bm4qvHhMxg3GFt-EGsHUw0tR2YQdk4AVUF%2BNgB5VABZXHRsAFdeXHEpKmc5ZDQsPEISSHIYADpPADUrW1bDSQaLDvBjXrAtAaDWuITIEGTUjOzcgqKJEABaSUQFKD481VryBACmRaXaNcVN7fVBg8Il8vXIM5qLg8WYNf4AE04lwYhWDgmrGwAJ4sIoTXIoMRiIA
DestinyAwaits , 04-14-2024, 10:01 AM
@QDrives okay. Thank you. I am checking now.
Sniper2 , 04-16-2024, 07:06 PM
@DestinyAwaits progress?
DestinyAwaits , 04-17-2024, 08:53 AM
@Sniper2 I got in touch with Infineon to get the help related to the data. Once I get concrete answers I will update.
