How Differential Pairs are routed on 2 layerd boards?
Parth , 06-23-2025, 05:45 PM
I am new to pcb. The image  that I have attached is of a esp32 dev board and the differential pair routed in green has no good return path so how does this board function well?https://dl.espressif.com/dl/schematics/PCB_ESP32-S3-DevKitC-1_V1.1_20220429.pdfThis is link to schematic of the dev board
Parth , 06-23-2025, 06:12 PM
QDrives , 06-23-2025, 08:05 PM
Why not go for a 4 layer board?What kind if signal is it?Do you want to have it work reliable?
Parth , 06-24-2025, 04:08 AM
Isn't 4 layer going to be more expensive?It's USB Signalyes but it is not supposed to be like automotive grade or industrial
ElHeim , 06-24-2025, 03:41 PM
Depending on the manufacturer, 2/4 layers price difference might be negligible. Looking at OSHPark, the price for square inch is twice as much for the 4 layer one, but you have to weight that against the benefits of being able to have a power and ground plane in between the signal ones.
QDrives , 06-24-2025, 07:51 PM
Of course 4 layers is more expensive.But you want it to work, right?
Parth , 06-25-2025, 03:43 AM
yes i want it to work
Parth , 06-25-2025, 03:48 AM
but my question was how does that pcb work , that is a official esp32 devkit pcb
Robert Feranec , 06-25-2025, 08:33 AM
two layer pcb 100x100mm $3.30
four layer PCB 100x100mm $12
Robert Feranec , 06-25-2025, 08:35 AM
I know it is more expensive, but in this case more expensive is still a good price. But of course it depends on how many products you are building.
Robert Feranec , 06-25-2025, 08:39 AM
You can route USB without controlled impedance and reference planes and it still may work fine. Sometimes there is no other way. Just then I try to keep it as short as possible (but it will still influence the quality of the signal)
Parth , 06-25-2025, 08:57 AM
ohk got it thanks
