Ground Polygon connection problem
Clarice Starling , 11-23-2024, 06:28 PM
Hi,I saw that the point shown in the image below is connected very weakly. Is there a way to fix this?
QDrives , 11-23-2024, 06:34 PM
Not only weak, but a production problem.The simplest solution may be to use rounded rectangle pads, with optionally a very low rounding.You will notice that the clearance then suddenly is not square either.
Clarice Starling , 11-23-2024, 06:41 PM
The point I marked is not a pad. It is a GND polygon covering the entire card. However, there is a very weak transition in the area I marked.
QDrives , 11-23-2024, 07:26 PM
I know, but look at the screenshot I share here.The left pad is square, the middle is rounded rectangle with 1% rounding and the right one has 50% rounding.Notice the polygon pour around them.So in your case, the polygon may connect properly if you set the pads to rounded rectangle.Then on the polygon, as I got slightly different results"Which version of Altium?What settings did you set for the polygon?
Clarice Starling , 11-23-2024, 07:33 PM
I am using standard settings for polygon and also noticed a strange situation.I am trying to fix weak connections manually like here, but if I make a road connection to strengthen a gnd line, it does not connect that road to the polygon and opens around it. Can we fix this?
Clarice Starling , 11-23-2024, 07:34 PM
why does it leave a space here?trace is GNDPolygon is gnd
version 25.0.2
QDrives , 11-23-2024, 07:43 PM
Yes, for one reason I do not know, the default setting for polygons is just terrible in that regard.You should change the setting that I point to in the screenshot here
Clarice Starling , 11-23-2024, 07:47 PM
thank you it worked 🙂
QDrives , 11-23-2024, 07:47 PM
From your screenshot - do not place a track like that between pads. Either go out and round or inside and round.If you leave it like that, after production (soldering) you will often see a "short circuit". I spend many hours trying to fix such 'shorts'.
Clarice Starling , 11-23-2024, 07:50 PM
is it good ?
