QDrives , 03-07-2025, 05:15 PM
First of all, Digikey is not the manufacturer. If you look at the screenshot from them, you can see they have a mistake. Either all 3 should be bi-drectional or uni-directional.Now for the other problem -- OnSemi does not mention either uni-directional nor bi-directional. So Digikey needs to 'create' this on their own.If you ask me, I would say this is a bi-directional TVS diode array.As for some of your other remarks:- Pins 10, 9, 7 and 6 are NC, as in Not Connected. This allows you to route traces through -- so a trace coming in at pin 1 route to pin 10 and continue to your IC.- Uni-directional means voltage is limited from -0.6V ... +5V. Bi-directional would be -5V ... +5V.However, the 2 diodes in series, that is in parallel to the zener diode, makes this non standard.
