QDrives , 05-01-2025, 10:20 PM
The problem spike is at 60MHz, next high is about 72MHz, that is in 12MHz steps. 12MHz is USB2 full speed clock. Your USB cable is generating the spikes.But USB does not cause the broadband noise. At least not the communication, it may be the antenna for the noise.In the screenshot you notice all the spikes at 12MHz steps, starting at 36MHz, 48, 60, 72, 84, 96, 108 and 120MHz.One way to test this is putting snap-on ferrite cores on the USB cable **at the PC end**. If the noise is gone  (broadband only!), it is the PC and not your device.Important question: was the USB cable mainly vertical?
