SkyDvv , 08-17-2024, 05:58 AM
I have an micro-controller that will be powered through a backup power supply, batteries.always connected, but as you can see the programmer has power-pin that will always be connected when programming, that's wrong something will blow up its a short circuit.If i decided to use OR controller, 2 inputs 1 output.both of them will be 3.3v with some other deciemals.is it safe?I feel like the controller will always switch between them and something will go wrong.I guess it's use is for 2 different voltage supplies not same ones, or i just miss something
