DRC Errors for mixed signal PCB layout
Techcurious , 08-14-2025, 03:55 AM
Hi All,I ran the DRC check after completing the PCB layout, but I got several errors. Please see the attached image for the most common errors. Also, does the front solder mask error can be ignored?  please help. Thanks.
moko , 08-15-2025, 10:12 AM
im not an expert but it seems like your components are too big for the way you aligned them and i believe that ur purple line around the board isnt closed there might be a gap somewhere
moko , 08-15-2025, 10:15 AM
ig google "front solder mask aperture bridges items" for more info
Techcurious , 08-15-2025, 06:53 PM
Yes I removed the arc, made it a rectangle shaped board, then it resolved the error. For the front solder mask error, I don't see it is bridging with different nets. Also so many people suggested in google suggested that we can ignore this error if the nets are not really shorting, I am using footprints from Phil's library, so I don't see any issue now. Thanks.
