Best way to route CLK signal with a focus on EMI
Michael , 03-04-2025, 06:36 AM
Helloi have a question that is facing the problem of EMI.What is the better way to route a CLK-signal especially when the focus is on the distance to the refering GND?From the videos i saw so far i catched that the distance between CLK and other signals shall be min. twice the width.But what about the refering GND e.g. when the layer is flooded ?In this case i have a 8 layer board, 2nd layer is GNDWould it be better like shown in the first picture ( red flood = GND; 0.5mm = 500mic ) oris the solution in the 2nd picture better ?Thank you for your answers.
Denis , 03-04-2025, 12:03 PM
Hi Michael, I'm trying to follow application notes and guidelines since I dont have enough experience. In all examples I saw, the crystal oscillator is close to the IC. In attached screenshot is a page from STM application notes as example
Robert Feranec , 03-04-2025, 12:07 PM
it will influence impedance of the track, I am not sure what is your target impedance. btw if you have GND plane under the track you may not need to do that. I recommend to watch this: https://youtu.be/9lEtkysFGGg
Robert Feranec , 03-04-2025, 12:08 PM
I almost never do copper pour
Robert Feranec , 03-04-2025, 12:09 PM
also maybe watch this: https://youtu.be/52fxuRGifLU
QDrives , 03-04-2025, 04:34 PM
In your first picture you have a co-planer waveguide together with a reference plane. That will lower the impedance of the trace.For ease of calculation use the second.Make sure that the trace impedance is 50 ohm and add a series termination at the source to match 50 ohm together with the impedance of the output.
