Ground polygon removed at the edges
nikhil2402 , 10-08-2018, 04:03 PM
Hello Everyone,
I have been facing the following problem:
When I pour a ground polygon and have cutouts around certain pads, the ground misses to fill at the corners of the cutouts as shown in picture below.
I had this problem sometime before as well but I solved it with some trial and error. But this time I am not able to get rid of this.
Does any one have a solution for this?
Thanks
Paul van Avesaath , 10-09-2018, 03:55 AM
I have the same issue once i a while, no solution found.. can live with it in most cases.. it is a rule thing or at least thats my guess... havent checked the altium forums for this particular thing..
mohsin_qau , 10-09-2018, 07:26 AM
Please review the Polygon-Pad Clearances and Polygon Dead Copper Region.
robertferanec , 10-10-2018, 02:52 AM
as @mohsin_qau is suggesting, have a look at polygon properties and rules. You may want to try to use smaller numbers there:
