Controlled impedance traces specification for manufacturer
IgorStojanovic , 09-27-2018, 03:50 AM
Hello to everyone,
I am confused about how to specify to the manufacturer which traces should be controlled impedance. The way how I did the previous controlled impedance designs is to rely to the manufacturer stack up and apply the proper geometry to the specific traces. I also put stack up table in a separate layer - manufacturing notes (learned from Robert). However, some manufacturers (cheap one) insist on doing it on its own. I suppose they doing it by modifying the gerber file and adopting the correct trace geometry. But, how it actually works? How can I tell them, I need that and that trace to be controlled impedance? Does it work like that I described?
Thank you in advance.
mairomaster , 09-28-2018, 02:47 AM
You can set the impedance controlled tracks to a specific width and describe this in the manufacturer notes. Then the manufacturer will know that those are the desired tracks that need to be modified.
IgorStojanovic , 09-28-2018, 02:53 AM
Yes, it makes sense. Thank you.
robertferanec , 10-01-2018, 12:43 AM
We always add screenshots with highlighted nets. It looks something like this (this is file called DIFF100-L3):
IgorStojanovic , 10-01-2018, 10:29 AM
That is very useful. Thank you Robert.
Paul van Avesaath , 10-02-2018, 03:03 AM
I Use mechanical layers and use text with reference info, because sometimes i make cutouts in the internal ref planes to change the impedance.. (the world of 75Ohms video sucks in that way)
