Blanket
keivan , 04-09-2018, 09:40 PM
Hello;
I tried to use blanket to connect some nets to net class but i can't use it and altium reports this error :
In addition i use altium version 17.
Thanks
Muhmmad Ahsan , 04-09-2018, 10:50 PM
For Blanket it should be compulsory to select Ports .!!
keivan , 04-09-2018, 11:04 PM
Thanks Muhammad
I tried with Ports,
but in any case, when i right click to finish drawing blanket it export that error!!
Muhmmad Ahsan , 04-09-2018, 11:10 PM
kevian ,
You will draw blanket according to your requirement ,but once you will reach your required point ,double click there and press ESC,
hope it will work for you
keivan , 04-09-2018, 11:33 PM
Thanks
It's important to place blanket around a net or port and blanket should include nets or ports.
Muhmmad Ahsan , 04-09-2018, 11:36 PM
it is important to include ports..!
if nets is covered under blanket ,so it will not make issue.!
Muhmmad Ahsan , 04-10-2018, 12:15 AM
its helped you ???
keivan , 04-10-2018, 12:24 AM
its helped you ???
Yes;
As I mentioned above, the nets or ports must be in blanket, and with this issue my problem solved.
Thanks for replying @Muhmmad Ahsan .
