Routing only one DDR IC
armin.salcin , 02-09-2018, 05:05 AM
Hello Robert ,
I'm not sure how to route only one IC of DDR memory ,should i use t-branch topology or fly by and how to get t-branch when you don't have 2 ic or more , or i should use any other routing technique.
Thank you !
mohsin_qau , 02-11-2018, 09:15 PM
In the case of single DRAM, the topologies are dependent on Termination Resistors scheme. On the basis of your board size constraints, complexity and cost factor, you choose the best topology.
robertferanec , 02-12-2018, 07:23 PM
If you only have CPU connected to one memory chip, you just do direct CPU <-> Memory connection.
armin.salcin , 02-14-2018, 07:41 AM
Thank you for answer !
