Any Mobile Phone Impedance
Ghild , 10-24-2017, 12:42 AM
I recently designing PCB connected to mobile phone jack for recording audio. yes, Impedance matching is at circuit side, but I want to know there is something I need to consider at layout side ?
I am using 2 layers PCB and stack-up follow manufacturer standard.
Thank you,
robertferanec , 10-24-2017, 12:20 PM
I am not an analogue expert, but if you are using 2 layer stack-up follow manufacturer PCB it may not be easy to match impedance. Also, if I would be designing this kind of circuit and if it's very small, I would not be maybe worried too much about PCB impedance. What I would be probably thinking about is if the phone antenna will not influence the circuit.
Ghild , 10-24-2017, 07:43 PM
hmmm I am not consider about antenna.. thank you Robert...
I have problem, my circuit only works well at some brand , example Samsung., but not at Lenovo, recording sound has static noise..
