Hello all,
After I have gone through the following data-sheet, I came across few doubts, can you please give your explanations in lines to them:
Output requirements: 3.5V, 2A and 3.3V, 1A.
Input voltage around 7.5V
Ambient temp: -40 to +60 degrees
Given in data-sheet:
Junction temp: 150 max
Junction to Ambient temp: 34 degrees/watt
Doubts:
1. From above values, can you please tell me will there be any over heating issues? What is the formula for calculating Max. Dissipated Power in SMPs?
2. I want to implement the same application circuitry provided in the data-sheet, Will it work? (consider I will changing Voltage divider resistors values, and Inductors accordingly to achieve desired outputs)
3. The output ripple given in an example is 30mV, will it effect more?
Awaiting your reply.
Thanks & Regards,
