Hello Robert,
Thank you for your previous response.
I would like to get one more confirmation, please clarify this:
SoC specifications: iMX6Q - MCIMX6Q5EYM10AC of pitch 0.8mm, and Ball pad diameter - 0.5mm.
Manufacturer minimum specifications: Drill size - 0.15mm, Pad size - 0.5mm.
   Can I achieve
0.1mm minimum spacing between Ball pad to Via(0.5mm-pad, 0.15mm-Drill) when I place vias in the BGA?
When I was going through your course you mentioned your design rules as:
Min clearance: 0.15mm - sqpinternational, Drill size: 0.2, and diameter:0.45mm.
   How would it possible to you to maintain 0.15mm spacing after placing 0.45mm Via in the BGA?
Awaiting your reply.
