@MadhuWesly, you may want to have a look at our Switching Power Supply course:
https://www.fedevel.com/academy/onli...design-course/Possibly, you can download our OpenRex Altium project and check out how we did the placement and routing of PMIC:
http://www.imx6rex.com/open-rex/a) you need to check maximum current for tracks and VIAs. Simple and free tool to do that is Saturn PCB toolkit:
http://www.saturnpcb.com/pcb_toolkit.htmb) c) for high currents and important loops in power supply I often use polygons instead of tracks. Usually the placement needs to be done the way, that current loops between inductors, transistors and output bulk capacitors are as small as possible. The best is to read layout section of a power supply chip e.g. have a look at this document (search for "PC Board Layout Guidelines"):
https://www.intersil.com/content/dam...6/isl6236a.pdf2) Read the document from 1 b) c) that may help you. You may need to be careful about routing signals close to some of the power supply signals (e.g. gate or tracks which are going to be very noisy)
