Hello Walid,
- normally we do it for number of prototypes + we do it on some boards from the first batch of mass production. However, some customers may require to test every unit - we used to do this in my previous job. In that case you really would like to have your own environmental chamber.
- I am not sure if there are some standards (there probably are), but we normally do the things which we think are important. We do quite extensive memory testing + we run functional testing of all the peripherals for different temperatures. Here you can see some of our procedures:
OpenRex Testing in an Environmental chamber
http://www.imx6rex.com/open-rex/soft...ental-chamber/iMX6 TinyRex Production Testing in Environmental Chamber
http://www.imx6rex.com/imx6-tiny-rex...ental-chamber/- we do not set any special parameters for humidity. We build the boards for Industrial temperature range and run the tests between -60 to +85C (or depends what is the top temperature, for some CPU boards we may go only up to 65C as heat from CPU will prevent us to go higher - board will stop working). If components have different temperature range, we still run the tests in a wide temperature range and we watch what peripherals will stop working and when.
- Yes, Hyperlynx from Mentor is the memory simulation tool which I found useful
