Pour Over Same Net Polygons
mehmetkazakli , 10-16-2016, 04:56 AM
Hello everybody,
I want to put all nets to same polygons as Robert did on the SMPS video number 5 respectively. But the result is not same. What did i do wrong ?
robertferanec , 10-16-2016, 09:18 AM
You may need to select: Pour Over All Same Net Objects
mehmetkazakli , 10-16-2016, 03:17 PM
Nothing has changed
robertferanec , 10-16-2016, 07:52 PM
@mehmetkazakli you need to select "Pour Over All Same Net Objects"
mehmetkazakli , 10-18-2016, 10:01 AM
Oh sorry i put wrong photo. I tryed again but same result
mairomaster , 10-19-2016, 01:39 AM
After the change you need to re-pour the polygon, did you do that? It's done from Tools -> Polygon Pours -> Re-pour All/Selected.
robertferanec , 10-19-2016, 08:21 AM
@mehmetkazakli, in your rules (Design -> Rules) check Design Rules -> Plane -> Polygon Connect Style -> PolygonConnect. This should be set to Direct Connect:
mehmetkazakli , 10-19-2016, 10:21 AM
Ohh thank you Robert . Finally i did.
Mariomaster, i already re-poured. But i did not work.
