I am doing single rank ddr3 routing in a 6 layer board with the following stackup:-
Signal(L1) -> Gnd(L2) -> Signal(L3) -> Pwr(L4) -> Gnd(L5) -> Sig(L6)
[ATTACH=CONFIG]n4176[/ATTACH](I am using Saturn PCB Toolkit for calculations)
Add Table
| Via(L1-L6) | Via(L1-L3) |
Height | 38 mils | 12 mils |
Step Response | 15.8 ps | 4.1 ps |
Signal Propagation Speed Top/Bottom 145 ps/in Inner Layer
175 ps/inI am confused which parameter to consider for length matching. Physical length or the Timing.
Lets say i have a 1.4 in trace in inner layer(L3) with two vias of length 12 mils each from Top layer to L3.
Total Length = Trace Length + 2 * Via Length
(I am not including Fan out Stub here)
Flight Time = length * propagation delay => 1.4*175 = 245ps
| Length (inch) | Via (mils) | Via mils | Total |
L3(DQ) | | | | |
Length (in) | 1.4 | 0.01 | 0.01 | 1.42 |
Flight Time (ps) | 245 | 4.1 | 4.1 | 253.2 |
L1-6(Addr/Cmd/Control) | | | | 0 |
Length (in) | 1.36 | 0.04 | 0.04 | 1.44 |
Flight Time (ps) | 197.2 | 15.8 | 15.8 | 228.8 |
L1(clk) | | | | |
Length (in) | 1.45 | 0 | 0 | 1.45 |
Flight Time (ps) | 210.25 | 0 | 0 | 210.25 |
Note: on top layer there is only clock differential pair without any Via. That's why i made it 10 mils longer to compensate. Also signal travels much faster in diff pair.
So in all the above cases the difference in Physical Length is 3
0 mils while the timing difference is
40ps. If i try to match according to the length which is usually done in the
pcb industry then i can have a bigger flight time difference and vice versa.
I would like to know that with the above calculations am i going in the right direction for ddr3 routing. I am curious to know which factor to take into account if going for much higher speed in GHz range. I know the tolerance depends on the timing budget. But excluding all these things which is the correct way for matching, Physical Trace Length or the Flight time.
I am a newbie. So sry if i asked something stupid.
thanks and regards
