Smart Grid Insert to create new pins
The Smart Grid tools are available in all the Altium Designer List panels. To use Smart Grid Insert to create pins based on spreadsheet data, first create a new component in a library, then open the SchLib List panel (Shift+F12), and you’re ready to go.
Select and copy the required cells in your spreadsheet. Don’t worry if there are columns in the selection that you don’t  need, the Smart Grid tools can ignore these.
Switch back to Altium Designer, rightÂclick in the SchLib List panel and select Smart Grid Insert from the menu. The Smart Grid Insert dialog will open.
The Smart Grid dialog has two regions. The upper region shows the data that is currently on the Windows clipboard, we’ll  call that the source data. The lower region is the objects that are going to be created, which we’ll call the created objects.  If your source data includes a header row Altium Designer will attempt to automatically identify the object kind, then build a list of created objects. A point to keep in mind, before you map columns the list of created objects will have the properties of the current Altium Designer default pin object. So for example, if you wanted all the pins placed at 180 degrees with a length of 20, then set the default values in Altium Designer before starting the smart grid process. That  way you don’t need to worry about adding those settings into the spreadsheet, or editing them in Altium Designer after the creation process. Not sure how to set the defaults? Just select Place » Pin from the menus, then before you place a  pin press Tab to edit the default values, then place and delete that one pin.
