IgorStojanovic , 06-08-2016, 07:24 AM
It is the first time I am doing a 4-layer PCB with Bluetooth PCB antenna, that should be 50ohm coupled with the corresponding IC. As my layer stack is TOP-GND (layer)-POWER (plane) - BOTTOM, Altium actually used POWER plane as a reference in the impedance matching. I just wonder is it valid calculation in my case, because, as I know from RF electronics,  microstrip impedance is always calculated in reference to GND ? Am I supposed to put GND plane just below the signal layer (TOP in my case) where the matching trace is placed ? I initially make the GND as layer because I have separated ground regions (Audio-analog GND, Digital GND, RF GNF) connected to the single point, and as Altium requires at least one plane for impedance matching, I put POWER as a plane. I am not sure what is the regular option..
