Originally posted by
robertferanec@mairomaster is right, the attached document doesnt have so many pages, you probably meant to say 237. It says:
Filled VIAs are something else - you put something inside them. From the explanation they just don't want solder to flow inside the VIA. Have a look here for explanation about VIA types:
http://www.pcbuniverse.com/pcbu-tech-tips.php?a=5"Non-Conductive Fill: A common misconception is that a non-conductive fill will either not pass any or only a very weak electrical signal through the via. This is not true. The barrels of the vias will still be plated with copper the same as any other via on the board, the only difference is the empty air in barrel is replaced with the fill material. This is usually done to prevent solder or other contaminants from entering the via or provide structural support for a copper pad covering the open hole in the case of a Via In Pad. Non-Conductive fill is another term for mask plugged vias."I normally just mask VIAs under the BGA and it is ok.
I don't think the manufacturer makes any holes. The via diameters are normally small and because of the surface tension the mask shouldn't flow too deep in the via hole, maybe just a little bit. Closing the air inside in such cases is not a big problem, if it expands it will just slightly crack the solder mask over the via so it can escape. That is what I know from experience and speaking to manufacturers. I am not 100% sure about it though.
As I explained above, it only could be a problem with vias in pad, since you have the solder over the via, hence the air expansion can crack the solder joint above.
EDIT: Hmm this multiple stacking of quotes still doesn't work for me, or I am doing something wrong.
