eugarte , 05-02-2016, 08:23 AM
If you rotate 45 or 90 degrees a component, the Top and Buttom Paste layers are not affected, but if you rotate a component (I did it around 30 degrees) in a different angle, happens the issue in the picture 1. In that picture there is a light gray rectangle around the component, bigger than the component and that light gray rectangle causes me conflict to place a component close to the first. This is why I think the problem remains in the Top and Buttom Paste layers, and this issue is causing me a lot of problems because mi PCB is small.
In other words: I place a component and I need to rotate it 30 degrees to the left to place it nice, when I do it, a light grey rectangle appears around the component. When I place a second component close to the first, it generates an issue.
I hope you can help me to solve this out.
Thanks and best regards,
