Stackup for DDR3 memory chips
Bermell , 06-25-2022, 01:37 PM
I would like to ask you about the following Stackup that I am going to use for the routing of 2 DDR3 memory chips and a FPGA
1.- Components
2.- GND
3.- Data bytes group
4.- Address command and control
5.- Power 1.5V
6.- Power 1.5V
7.- Address command and control
8.- Data bytes group
9.- GND
10.-DDR3 Clock, and components
I know, the most important groups, are the Data bytes. I mean, each data byte should be in the same layer and doing the same changes between layers, but what about address command and control group? I can't keep all the signals of this group in the same layer, so and this is my question, what do you think about using the layers 4 and 7 of my Stackup, for routing this group ?
Thank you very much in advance
robertferanec , 06-27-2022, 08:05 AM
It could be possible. Be super careful about parallel tracks on layers 3/4 and also on 7/8. If you are not sure, try to simulate it when you finish layout. However, personally I would probably add GND layers between 3/4 and 7/8 if that would be possible.
PS: From my experience usually it is not so simple to have 5/6 1.5V only, usually there are many other powers under the CPU/FPGA, so often these power planes can't be so simply routed over all the memory tracks.
Bermell , 06-27-2022, 12:17 PM
Thank you very much Robert. I am agree, it is always much better to use a GND plane as reference for the memory tracks
Bermell , 07-05-2022, 12:43 AM
In addition to this present post, I did other one with the title, "About 1080 Prepreg for getting 40 Ohms Impedance in Top and Bottom layers"
in which I was thinking of using a Stackup similar to the one the OpenRex card has.
I am now considering using this new layers configuration:
1.- Components
2.- GND
4.- GND
5.- Power 1.5V
6.- Address command and control
7.- GND
9.- GND
10.-DDR3 Clock, and Address command and control
Layer 4, is not a GND power plane , but a GND polygon with the same size that the 1.5V polygon of layer 5
Can you give me your opinion about this new Stackup. What do you think about using the layers 6 and 10 of my Stackup, for routing Address command and control group ?
I know that the speed signals, will be different in layers 6 and 10.
robertferanec , 07-09-2022, 03:20 AM
I would try it.
PS: But I am still a little bit worried about not maybe not having enough space for power planes under your chip. Be sure you can connect all the powers before routing.
Bermell , 07-12-2022, 12:25 AM
Thank you very much for your answer, Robert.
Finally I have chosen to use 12 layers as you suggested in a previous comment, adding 2 GND layers to my Stackup
binayak , 07-27-2022, 11:45 PM
Bernell,
Just a doubt - are you using DIMM or individual chips? Only in the DIMM case, the CAC lines are referenced to power.
