R0 ohm
rachot , 04-02-2022, 06:33 AM
I found this circuit from Antmicro opensource hardware used in Jetson nano base board project.
Why they put R 0 Ohm in this circuit?
Thank you
qdrives , 04-02-2022, 04:17 PM
Zero ohm resistors are often used to allow optional parts or change the signal paths. It allows you to 'disconnect' a part of the circuit.
A little overkill here in my opinion.
rachot, 04-02-2022, 06:35 PM
Thank you sir.
Ant1882 , 04-04-2022, 07:00 AM
I'm guessing in this case it gives you a chance to add a small series resistance if you have issues with radiated EMI maybe?
qdrives , 04-04-2022, 02:40 PM
@Ant1882 You would need to see the bigger picture (schematic and layout) if this could be for EMI.
For the reset I would rather pick a 1k resistor or so, as this allows you to physically reset (during development) with damaging anything.
