Hello everyone.
I will ask a question. I cannot use the TPS65127 IC used for AM335X because I have supply problems.
For this reason I have to choose a new PMIC.
Here is the link of the manual for AM335X series:
https://www.ti.com/lit/an/slvaee2a/s...l=https%253A%2I have attached the document to the post.
Suppliers say that they can only give the TPS650250 IC. "SPEED GRADE SUPPORTED (MHz) max 600MHz".
However, 1GHz in the TPS65217 integrated.
For AM3358, it is given as "Arm MHz (Max.) 600, 800, 1000".
I was wondering if it would be a problem if I chose the TPS650250 IC with the "SPEED GRADE SUPPORTED (MHz)" option at 600MHz.
What problems could this cause?
I am waiting for your suggestions on this matter.
@qdrives, @robertferanec
