Schema library structure
suleymancskn , 01-09-2022, 11:23 PM
Hi Fedevel Family;
I'm creating my own schema library.
for example i have many resistors with different values. I provide in-house tracking with the ID numbers of the resistors.
As the number of resistors increases, my file size increases for this reason.
For example, can I create a component named 1206 resistor and create subcomponents such as 1R, 22R,33R.. under it?
Note that I want to give a separate ID for each component.
Thanks in advance for your help, regards.
@suleymancskn
robertferanec , 01-10-2022, 01:28 AM
You didn't say what software you use. Generally, in libraries there should be Components (includes for example info about manufacturer, part, supplier, ...), Symbols (schematic symbol), Footprints (pcb footprint). A component should be linked to it's specific symbol and footprint.
Sometimes libraries are created only from symbols (schematic symbol + info about component) and footprints (pcb footprint).
suleymancskn, 01-10-2022, 01:33 AM
Thanks robertferanec for your answer.I am using Altium Designer. Can I create a single resistor and sub-resistors (different value) under this resistor like logic gates?
robertferanec , 01-10-2022, 01:39 AM
There are no "sub-resistors" in Altium.
This will give you an idea how it works:
qdrives , 01-10-2022, 08:34 PM
Create one library for resistors, another for capacitors, and again another for...
- Inductors
- Discretes
- Power
- Logic
- Connectors
- Board (fiducials, etc.)
etc.
No need for sub components.
Name the parts so you can sort it the way you want. (Size -> Value)
