swap USB lines in the PCB
diegopm , 09-12-2020, 06:44 AM
Could be a good solution for swapping USB lines to put two 0603(in) R185 R186 resistors in series for doing the swap?
Thanks.
robertferanec , 09-14-2020, 02:38 AM
Usually, when I need to swap differential pairs, I change layers. But, this is an interesting idea. Honestly I do not know how good this is. To see the real impact you would probably need to measure the USB interface.
PS: From my experience, USB 2.0 is not very sensitive and it usually works fine even if it is not perfectly routed - especially when a short and direct connection is used.
