Footprint
Ashish1710 , 10-09-2019, 12:56 AM
What is angular ring? and what is the minimum size of angular ring?
Paul van Avesaath , 10-09-2019, 01:21 AM
annular ring is the area around you via hole.
normally the minimum width of the annular ring is 0.15mm (6Mil)
Ashish1710 , 10-09-2019, 03:11 AM
@Paul van Avesaath thanks for reply ..
annular ring is depends only for Via hole or through hole components also?
Paul van Avesaath , 10-09-2019, 03:17 AM
same for " holes" on your throughhole components. BUT, there should be a reccommended footprint design for your component in the datasheet.
if not try to look at similar component datasheets.
for through hole components the annular ring will determine the solder quality because your solder "heel" is mostly determined on the size of the annular ring.
