robertferanec , 07-21-2019, 11:10 PM
I agree with @milos.stankovic I would not route high speed interfaces such hdmi, ethernet, usb3 on 2 layer PCB.
- About layout and placement, have a look how they placed decoupling capacitors on the reference board. Usually you may find them on the bottom layer under the pins (usually I place them under the chips).
- I do not know much about your board and the chips, but I often route under chips, There may be some exceptions (e.g. do not route directly under crystals or be careful about power supply area), but generally there should not be problem routing under chips.
