Hello @Didan
  The bus impedance of the RS485 is approximately 100-120 Ohms differential and control trace impedance as ~50 Ohms
Make sure to follow below for efficient RS485...
- Since you have 2 layer board, use a ground polygon beneath the RS485 communication (Both Control and Bus circuitry)
- Several points in the layout as shown in the attached image can be improved, however you can start off by placing the component as shown in attached image as this will reduce stub length.
For the Saturn PCB calculator:
- Differential Pairs tab -> Play around with the values and use conductor height as you dielectric distance
- A quick example gives a impedance of ~125 Ohms with
                           -> Conductor width = 18 mils
                           -> Spacing = 6 mils
                           -> Height of conductor (this is distance from plane) = 60 mils
For reference document..
Search the web for "RS485 layout guidelines" and you shall find what you are looking for.
A good reference at
https://www.renesas.com/in/en/www/do...data-links.pdfThank you.
