RF components footprints with grounded vias
maxg31 , 11-07-2018, 09:47 AM
Hello everyone,
I made the footprints of this components :https://www.minicircuits.com/WebStor...odel=SXHP-5%2B
But as you can see in the suggested layout (https://ww2.minicircuits.com/pcb/98-pl230.pdf), there are lots of grounded vias (in purple).
I would like this vias to be integer in my footprints but I have to add lots of pins with a through hole padstack (26 pins to be precise). I don't want this 26 unused pins in my schematic in capture because I have to attached these pins to the symbol and it's a lot.
Is there a way to add lots of grounded vias in a footprints without add them in the schematic ?
Thank you
robertferanec , 11-08-2018, 02:31 AM
I do not remember exactly, but I think when you delete pin name, the padstack will become a mechanical part. This way you may be able to create VIA padstack, then add them through Layout -> Pins, select the added "VIA pins" and delete their pin names (that should make VIA pins just VIAs). Let me know if that worked.
maxg31 , 11-08-2018, 07:43 AM
Hi Roberts,
Thanks for your quick reply,
You were right, without names pins become mechanical pins but I cannot convert the mechanical pin in vias and I'm still not able to connect them to the dynamic shape ground plane to the pins
robertferanec , 11-08-2018, 07:53 AM
Maybe in footprint use static shape? But ... it looks like you already have static shape there?
maxg31 , 11-13-2018, 03:13 AM
Yes I used a static shape for the footprint ground plan. I just wonder if the dynamic shape of the board and the static shape of the footprint will merge ?
Thank you
robertferanec , 11-14-2018, 02:42 AM
Honestly, I do not know. This is a special component, but I normally do not use this technique. I would only maybe used a special PAD shape and added VIAs during layout. I do not place VIAs into footprints as I often need to move them and having them defined in footprint creates limitations during layout.
Paul van Avesaath , 11-19-2018, 12:33 AM
I usually add a hidden pin "0" underneath a defined GND connection in the schematic symbol. then use the identifier "0" for all different holes / via's / pads that way you do not have to worry about it... (works great for pressfit cages and all other stuff. see the attached picture.. you can add as many pads/via this way getting you the desired result. should be doable in cadance the same way... right?
