OrCAD can't display via properly
Piotr , 06-28-2022, 07:18 AM
in my design I can't display via with hole.
Picture on left side is with correct via, picture on right side is without hole in via.
I can only create vias without holes.
Many thanks for help
ntalukder , 07-07-2022, 09:17 AM
In my design its same I thought it works like that in 17.4 If you come across fix let me know as well.
robertferanec , 07-08-2022, 12:16 AM
Could you attach a screenshot from padstack editor? is the hole defined there correctly?
ntalukder , 07-08-2022, 05:18 AM
This is what I have in my padstack Editor.
robertferanec , 07-09-2022, 03:31 AM
and in drill tab?
Piotr , 07-12-2022, 12:43 AM
Please see attached tabs.
All the mounting holes looks as this via.
I'm using also 17.4 version.
robertferanec , 07-12-2022, 03:05 AM
Hmm, this looks ok. Do you see other holes in your PCB? eg. the holes in through hole pads?
Piotr , 07-12-2022, 03:51 AM
I can see all other holes same as vias:
Maybe there are some global properties, which cause this view.
OrCAD PCB Licence: 17.4-2019 S028 [3/9/2022]
robertferanec , 07-12-2022, 05:42 AM
Oh, I think I know what this could be. Try Setup -> Design Parameters -> Display and see Enhanced display modes. Play with the checkboxes
Piotr , 07-12-2022, 05:57 AM
Many thanks, this checkbox resolved vias display issue.
