Allegro PCB first configuration after instalation
adamS90 , 03-03-2022, 12:17 PM
does anybody have configuration/setup files for Allegro PCB Designer?
I mean the files with layer colours settings, with the list of different visibility views (assembly, silkscreen, top, bottom etc) and all other setup files (maybe some silkscreen text sizes file), so that I do not need to configure everything from begining, because now after installation I had all layers in green :P
Thank you,
Adam
robertferanec , 03-04-2022, 05:22 AM
I don't think there is an universal color file what everyone (most people) would use - but the colors should not be all green by default.
PS: I often change colors for specific board (even in Altium) as I try to have visible difference between the layers that I use the most.
adamS90 , 03-24-2022, 04:41 AM
Thank you Robert!
Have some more quesstions:
1. I'd like to connect from pin to pad in the way that is drawn with blue pen:
but Cadence does not allow for that. How can I do that?
I tried move the middle cline segment with "Shift" key but still not possible
robertferanec , 03-26-2022, 02:11 AM
it should be possible. did you try to change grid to a smaller number?
