Need to move existing component by 100mills downwards
Dharitri , 10-06-2021, 11:25 PM
I need to move the existing connector J32 by 100mills downwards.
When i click "info" it shows location 733.518 1326.148
Hence, to move downwards by 100mills i have used command x 733.518 1226.148
But, it is not alligned correctly and gets moved to a arbitrary location. Please help
robertferanec , 10-07-2021, 02:34 AM
Maybe I would try to change the units (that could give you nice numbers) and then moved it? Weird numbers are usually visible when something is done in different units.
Dharitri , 10-07-2021, 06:05 AM
I tried command iy -100
and the connector moved down by 100mills. I got this idea from your tutorial "
Learn OrCAD & Cadence Allegro Essentials"But, thank you for the suggestion!
Regards,
Dharitri
robertferanec , 10-11-2021, 05:28 AM
Perfect! Yeah, that also helps.
