Capture startup
w2fdr , 01-05-2021, 12:43 AM
I'm facing some error in the command windows on Capture startup, maybe for a wrong configurazion file manipulation. What is the first file read by capture at start up ? How can I modify the start up sequence ? Regards Franco
robertferanec , 01-06-2021, 12:48 AM
@w2fdr honestly, I do not know. The best may be to talk to Cadence .. possibly re-install(?)
w2fdr , 01-07-2021, 08:57 AM
You are right :-)
I've an other topic :
in you test pcb
Try it by yourself - YOUTUBE - iMX6Rex module - T-Branch ADDR CMD CTL Length Matching.brd
I' cant do DRC or short routing the net because allegro try an autoroute to avoid conflicts, and it's god .
How can i set this beavius on all my PCB ?
Tks
Regards
Franco
robertferanec , 01-11-2021, 01:43 AM
iMX6Rex module has not been designed in Cadence. It was designed in Altium and imported to Allegro. Running DRC would not work well on that board - unless you set all the rules and everything.
